I posted this on another board as well but i figured i would post here as well.
winter is approcning and I am planning my projects and getting ready to purchase parts.
I remember seeing a thread aobut suspension kits on here at some point but i coudn't find it again.
I plan on buying the parts from VB
For Phase 1; (now to x-mas)
Major front suspension kit ($110)
Shock kit front and rear ($80)
Front sway bar bushings and hardware (+/- $20)
Coil Spring set ($60)
For Phase 2; (x-mas to spring)
Rear Leaf spring ($150)
Rear spring bushing set ($10)
Rear bushing set ($20)
Diferential mount bushing set ($20)
my questions are these.
has anyone used the above parts from VB? how was quality, etc....they have to be better than the worn out units i have on there now.
should i do the steering rack mount bushings while i have the front end apart?
should i replace the front spring plates? the ones on it now look ok.
should i buy the regular hieght coil springs or the lowered springs?
should i go ahead and do the wheel bearings while i have it all apart? (current bearings seem fine)
any special tools needed(triumph spicific)?
any parts i have missed?
thanks for the advice.
