Support bracket for the rear suspension damper link
bob hughes
Arrrrgh
Having heard a rattle, seemingly from the rear of the car, I looked through the back seat area down onto the damper expecting the bolts to be loose but they were tight. The link between the damper and the back axle looked as if it needed replacing so a set was ordered - a good price from Ebay. Today I stripped the old link out on the drivers side only to find that part of the bracket, welded to the axle, had sheared and that the link itself was in reasonable shape. DOH..
I suppose on the plus side, if I had not disturbed the link I would not have known about the damage to the bracket. I am now forced to do some welding with the petrol pump and lines in place - not a situation that leaves me with a nice cosy feeling, but I do have a glass fibre cloth that I can wrap around the pump to isolate it from potential sparks.
Has any one else experienced this problem?
:cheers:
Bob
Agreed. Weld in-situ is the only real option. Welding of bracketing was performed twice on my car: first to create a new left side bracket to replace sheered off original and second, to repair a crack developed on the right side bracket join. Both times the gas tank, rubber fuel hose and pump were isolated / protected with barriers (welding blankets etc.). IIRC area of repair was extensively prepped to remove paint to expose good bare metal for mig welding. But, of course you knew this.
Repairs made 15+ years ago are still holding. Emergency / parking brake bracket is a different story - small cross-sectional area and lots of leverage here can weaken the join over time. Good luck your with repair. GONZO :encouragement:
Bob, I welded mine in place about 15 years ago and it held. Then when I restored the car 3 to 5 years ago, I had the complete axle out and rebuilt it at that time. The job done 15 years earlier was pretty ugly looking having welded laying on my back but it held. My fuel lines are solid copper tubing and I believe as long as there are no leaks and no fumes you will be alright. Lay wet rags on everything to protect from heat and sparks. If you smell fumes don't do it.
Thanks Guys
That gives me some reassurance, about to start getting ready this week end or just after as it is Easter.
Gonzo - I have already dealt with the emergency brake or at least some of it some years ago, very difficult without removing the fixed section over the prop shaft.
:cheers:
Bob
All done, I bet your welding was better than mine Vette and the rattle/squeak has gone - yippee
The car nearly killed me though. Did a foolish thing and balanced some wooden blocks on the jack having already taken it up to the max, to give some extra height. Put the axle stands in and did the job, on dropping the car down on completion, I foolishly tried to drop it in one go - big mistake, the wooden blocks tilted and the car came off the jack all together and bounced - some may say a good test for the bracket, I say I was lucky to be out of the way at the time.- No damage done to the car but my pride is a bit dented. I should have used my big garage jack from the start.
:cheers:
Bob
Good to hear you made it out alive. Thanks for the update.
