Suddenly showing up in unreadable tiny fonr
ncbugeye
BCF is now displaying in an incredibly tiny illegible font, whereas all other sites such as Google, etc are normal.
What did I do to make this happen?
How can I repair it?
I don;t know but on most browsers you can make fonts larger or smaller. Usually this feature is found under the View menu on the browser.
No, it's ONLY BCF that shows up small. EVERYTHING ELSE is normal. I use Firefox normally, but when I switch to IE it is normal.
This happened suddenly yesterday.
I'm not sure what is going on then. Nothing has chanced here that I'm aware of to account for the problem. Is anyone else having this issue? (What "Style" are you using and have you changed styles recently)?
No change here...
Everything is normal for me also.
I finally tracked it down. It was some sloppy keyboarding on my part.
In Firefox, showing (say) a page from BCF, if you press and hold ctrl and then press + (plus), the font size is slightly increased. If you press and hold ctrl and press - (minus), the font size is slightly decreased.
If you keep doing either of the above, the font gets progressively larger (or smaller)
Thanks,Chris your tip works on IE also.--Keoke :thumbsup:
