Recently my Hyundai Santa Fe 3.3L started running very rough and I was getting code P0018, which was indicating an oil control valve problem on one side.
It was not a trivial task to replace the oil control valves (OCV) (I replaced them both since the car has high miles and I don't want to have to pull the intake again any time soon), but finally I got the job done tonight after 2 days of removing the upper plenum and lower intake manifold to gain access to the OCVs. (The are a real pain to get access).
I also replaced all the spark plugs (with NGK iridium) since, in order to gain access to the rear 3 plugs, you must pull the upper plenum off (which itself is a pain).
My Santa Fe runs like a new car now! No more codes and also no chain noise on startup like I used to get.
I am a happy camper!
