Spent some quality time with my 1275 tonight. Had a mix of success and failure:
Successes:
* Boxed up the head and carbs to send to Hap tomorow (hey, the little things count).
* Using a borrowed breaker bar and a 2x4, removed flywheel bolts.
Failures:
* With bolts out, flywheel didn't budge a bit.
* Crank pulley bolt wouldn't budge either, even with my floor jack handle over the breaker bar for a little extra length -- not even a smidge.
* In a stupid act-then-regret move, smooshed the oil pickup screen jobbie when I lowered the engine to the ground. I think I can un-smoosh it, but I felt a bit dumb none the less. /bcforum/images/%%GRAEMLIN_URL%%/blush.gif
I'll try one more time with the long breaker bar, but I'm thinking that an impact wrench will be needed for this one, unless there are any other thoughts.
Successes:
Failures:
