I am cleaning my carbs up due to the old fuel that was left in them. The rear one ones almost perfectly clean, and took very little cleaning. The front carb though, was all gummed up and the piston was even sticking do to so much old fuel/varnish. During the process of cleaning I tried to remove the jet assembly from the jet bearing and it wouldn't move. It won't twist or slide or do anything. I tried brake clean, carb clean, penitrating fluid, nothing worked. So how can I get the jet assembly out?
