AUSMHLY
"SU Carburetor sync synchronizing kit."
Thoughts?
This is on Ebay. FYI $98
"This kit makes it a snap to synchronize your carbs without removing air cleaners or ducting. Simply remove the damper caps and install the collars, insert and zero the gages and adjust the airflow with the air adjustment screw so that both (all 4?) carbs read the same.. Instructions will be provided."
https://www.ebay.com/itm/SU-Carbure...179851?hash=item46aee8720b:g:SxgAAOSwSCZbQatk
Thoughts?
