Although the file is bigger, you might find the version at https://docs.google.com/file/d/0B2H...M2U2LWJhYWUtMjEyZDgxMzUyNzUw/edit?usp=sharing to be easier to work with. It has some bookmarks and comments added; plus is not write- protected so you can add your own if you want.If you haven't already, you should do a complete tune-up. But take a look at page 33 of the Practical Hints manual for H6 carb adjustment:
https://www.triumphtr.com/manual_tr3.pdf
Tom
Yes, I do. And ya' know its funny cause the car, this past summer,
was running hot and after fumbling around with the ignition cause it
was also running lousy, I found the needle had fallen down into the jet.
I reset it and secured it. The car ran great!
But I know somehow the black smoke and the fuel mix have to be straightened
out. My one carb is leaking and I don't know if this might be flooding it.
But parts (cork seals) are on the way. I wonder if I should replace jets and/or needles?
