I have a '75 MGB with twin SUs fitted. It runs rather lumpy (it has a mild cam upgrade) and it smells as if it is running rich. The front two plugs look OK. The back two are white and burnt. I'm thinking the carbs are not set up correctly - front rich, back lean.
Can someone suggest a novice's guide to getting the basic carb settings right - or at least close?
Thanks all
Thanks all
