From another thread below:
Here are some questions I've always had:
1) The SU needle rises when you hit the accelerator. Is that because the butterfly valves open and let in
<span style="font-size: 14pt">MORE AIR OR MORE FUEL ??</span>
Which is it? Chicken or the egg?
3) And how does the fuel then get evenly spread to all 4 cylinders?
2) Also, how does the extra fuel get into the cylinder to explode in the first place? Does it just run sloppily down the intake manifold when the butterfly opens? That seems too primitive. If the gas is being sucked into a vapor after running up the jet needle path, that causes me to ask the chicken or the egg question again.
<span style="font-size: 14pt">How is the engine drawing in greater air to lift the needle before the extra gas got there in the first place??</span>
DrEntropy said:SU's are dead simple once you grasp what's happening in there. About as complex as a bathroom faucet.
