Jim_Gruber
After seeing the note posted about almost burning BE up due to leaking gas flow overflow tubes I am pondering. IS it normal to run SU Carb overflow to a rubber hose and down to underneath car. Bugsy my '68 with 1098 does not have any sort of overflow tube in place and I do notice the small of gas emanating from under the hood at high speeds. Got the low speed smell gone, just noticing at higher speeds. Trying to figure out if I have a leak or smelling raw gas from too rich exhaust fumes.
Are you using any sort of Right Angle adapter on the hose or clamping on and running underneath the car.
