BritCars54
Member
Finally cool enough in the southwest to resume work on the 60 TR3A.
The "leak proof" o-ring on the jet assembly did not live up to its billing. As I saw on many SUs at Triumphest this past weekend, the bottom of the jet may have some moisture. Mine drip fuel, and definitely coming from the jet. So, as I pen this post, my new cork seals are soaking in oil (seems to be a consensus about this, and I did not treat the seals this way for the first attempt). As I prep to pull the jet assembly, I note that when the choke linkage is operated, the jet shafts do not slide easily. Is there something else I should be thinking about as I pull the assembly again?
