FYI, DOT 3 is fine for a '79 Midget, and the owner's manual for mine (a '77) confirms this. The "natural rubber" argument for using DOT 3 is pretty much limited to ones from the 50s that actually did have pure rubber instead of the nitrile used later. Still, they do have latex in them, so you don't want to get anything petroleum based on them or you will ruin them. Can't explain why after several months it would have started sucking air, but the one thing I did discover is that the clutch pushrod makes a tight seal with the dust boot on the slave cylinder, so if you have to remove the slave you will likely have to bleed it even if you didn't open the hydraulics. When you put the slave back in the pushrod acts like a piston and builds up an air pocket which burps its way past the seal once you work the clutch a few times. This happened to me a couple of times before I figured out what was going on.
