I just recently had the pleasurable (sarcastic) experience of flushing my transmission today, cleaning the outside of it (a foot of accumulated rock hard grease that found it's way onto me) and doing several other things that needed to be done.
Something that this car has always had just got worse for some reason.
This car has always had a very slight off idle stumble when going up a hill in low gear just as you're about to let off the clutch and start moving. Once the clutch is out you can go through any gear at any throttle and it won't stumble.
I just recently adjusted the timing, synched the carbs, cleaned and re-gapped the plugs, checked gap on Pertronix module, checked dash pots and made sure that everything electrical was tip top. The plugs came out a perfect medium tan (first time ever) so I didn't dare touch the mixture. I'm pretty sure it's got something to do with the carbs. Which part of the carbs though? I checked both chokes and they were open and the car was warmed up to normal temperature.
I almost forgot to mention... not only did it stumble worse than before it also gave a muffled backfire as well when accelerating in low gear around 1500-2000 rpm.
Thanks!
Thanks!
