TR3driver
Great Pumpkin - R.I.P
Has to mean that either the port is blocked, or you have a huge leak somewhere. The capacity of the entire system is only a freckle over two (US) gallons, and the drain tap is way down low. Unless your shoes are wet, or the crankcase is full of coolant; the drain port is blocked.doughairfield said:I opened the coolant valve on the side of the engine block this morning just to see if coolant had started filling the water jacket, but it was empty. I poured 2 gallons of coolant into the radiator before I started the motor for the first time
Happens all the time, mine is almost always blocked every time I do my semi-annual coolant flush & change. The crud blocking it didn't necessarily come from the engine, it might have been lurking in the heater (for example). The drain is located at the lowest point of the water jacket, where coolant flow is slowest, so that is where any sediment will settle.
