jcatnite
Driving to work yesterday morning in the Midget and all was good. This was the first time I had it out in about a month so I was really enjoying the ride. I arive at one of the few stop signs I have in my journey through the country and when I push in the clutch the engine races to about 4k. Back in my older days when I raced stock cars if that happend you could pull up on the accelerator pedal and calm the engine back down. In fact I have raced a full race with a broken return spring before...didn't finsh that well thought. At any rate, I was able to get the engine back down to about 2.5k. I pulled over in the dark and fiddled with the linkage and brought it back to idle. Thinking I had a lube problem I limped it on into work. To make a long story short, it turns out that it wasn't in the linkage at all. The throttle cable had frayed at the pedal linkage and probably made a bird's nest in the sheath for the cable. I only had a couple of strands holding it on! Luckily Vicky Brit had one that I could obtain for a minor fee so in a couple of days we will be back in business...
Just thougth I would share...I can't readily see that end of the cable on my spridget as the pedal box is painted black and you have to stand on your head to inspect it. I've added it to the weekend checklist of things to go over at least once a month...lol
JC
JC
