Seems like everything is frozen on this project! My newest challenge is getting the pistons out of the calipurs. After removing the calipurs and cleaning them up a bit, I applied some line pressure to push the pistons out. On both calipurs it took over 100PSI to get one of the two pistons moving. The second piston in both calipurs is now stuck. I've tried to pry gently, at first, on both sides of the piston at the groove for the rubber bellows. Solid. The pistons that came out show rusted patches and will need to be replaced, so I am assuming that the pistons that are still frozen are even more rusted.
Any ideas on how to get a grip on these things?
Hi Guest!
