stuck clutch
JBMd
have 1976 tr6 setting 3 years have started car ran in all gears slammed on brakes put on stands ran slammed on brakes also turned off car while running not able to brake loose. Will try anything .also bled clutch have small leak on slave
Are you sure your clutch pedal pressure is enough to release the clutch ? TR6s need perfect clutch hydraulics and release adjustments even when the internal clutch parts are ok. I've worked on many British Cars over the years and have yet to have one with a stuck clutch, though.
