TR4
I have posted this issue before but I have yet to resolve it. My Stromberg carbs were recently professionally rebuilt. When I first put them back on, the motor fired right up using the choke. The rpm's were as they should be and when the motor warmed up, I pushed the choke in and it settled down to about 850 rpm so I was excited. There was one problem though, the one carb was leaking at the choke spindle so I called the guy who rebuilt the carbs and he suggested I reset the floats so I did that and the leak seemed to go away. Now, after the car sits a while and I pull out the choke, the car will start but sputters and stumbles until I push the choke back in. It will then continue to sputter and stumble until it warms up and then it runs just fine. I tried to pull out the choke when the engine was warm and it started to sputter and will even quit if I leave the choke pulled out. I sure would appreciate any advice on what to try to get the choke working properly again.
