Hi all,
I am trying to syncronize my CDSE carbs on my 1970 GT6+.
The back carb is sucking less air then the front. and when I lift the air valve with a screwdriver the engine bogs, which indicates a lean mixture. With this said, there is no adjustment on the bottom of the carbs like on the CD150, only an idle screw, a fast idle screw and an idle trim screw which requires a CO2 analizer on the exhaust to set to the correct mixture.
How do I syncronize, balance and adjust the mixture.
Any ideas?
Joe
Any ideas?
Joe
