stroberg fluid level?
wangdango
Have just rebuild a pair of strombergs, need to add fluid to them (i have su damper oil, is that ok?). I am a bit confused on what the level should be? Any ideas?
thanks
Ed
SU damper oil should be fine.
When you look into the opening, you should see an inner ring which is actually the top of the central rod. You can fill to that point. However, the level will slowly drop somewhat below that point in operation, which is fine. The excess seeps down between the rod & the cover, to lubricate the rod.
It's not all that critical; as long as you can feel some resistance when you insert the plunger, then there is enough oil for correct operation. Any gross excess will be forced through the vent and run down inside the carb throat, to get burned harmlessly.
What Randall said, but keep in mind if the oil disappears very rapidly you might need new seal in the chamber. Not a big job if in fact it needs to be done.
Let us know where you get to with it.
Ed,
I add oil to mine until the rod's black screw top stands
about 1/4" above the metal edge of the fill opening.
If the rod and black screw top drops straight down onto
the metal, I know I need to add oil. I check mine once a week.
best regard,
dale(Tinster)
I rebuilt my Strombergs about 5 years ago and have never had to add oil. They have never needed any but I don't drive the car more that 7 or 800 miles each year.
