[ QUOTE ]
Thanks Keoke, Although I have about 35 years of body work experience I have a total of zero working with aluminum (probably can't even spell it correctly) There is also some nose damage were the badge bolts on ,looks like the engine wacked it on it's way out when po removed it. Also some stress cracks were it attaches on the bottem to the frame tabs. Can these be welded with a tourch and aluminum rod?
I had a local shop weld them but I am not pleased with the results, thought I may be able to do better myself.Kinda looks like a bird crapped on it. (cost $60 bucks).
Is the glue product for applying body panels an option for use on aluminum? Thought maybe I could double the panel were it bolts to the tabs on the frame. Thanks Bob
[/ QUOTE ]
With that type background all you need to do is slow the hammer down.Yes you can weld the aluminum with a torch IMOP its the only way to go.The nasty part about aluminum that we do not see with the ferrous metals is that it becomes work hardened when it is being straightened.This requires that the areas be stressed relieved and as far as I know only a torch will do it.What you do is to lay down a heavy coat of soot with the torch then burn it all off if you are not sure you did it good enough do it again this requires different torch settings I think you realise.The modern metal adhesives surely should work. However, I have no experience with them. A little practice with the torch on aluminum should get you up and runing in a relative short time.A bit of reading up will help too.---Fwiw--Keoke
