OK, let me set the scene. I am running 15" Panasports with 205/70 Michelins on my four corners. Because I have an aluminum gas tank, which is over-sized, this size tire won't fit in my spare tire cubby. Sooo, I used one of my OE steel wheels and fitted it with a nice, new Vredestein 185/15 tire. All was good until I found that my spare kept losing air, however small an amount. I changed the valve and no good. Still dropped to about 20lbs after 2 months. I figure the wheel has a minor leak and had the bright idea of just tubing the spare! Called Coker (from whom I bought the Vredestein) and relayed my dilemma. They said just tube the tire. Sent me a radial-compatible tube and I promptly went to the local tire shop to have it installed. NO WAY, they said. Cannot put a tube in a radial tire! Refused! Called Coker. They said baloney. So, what is the call? Can I mount a radial tire with a tube? Frustrating, at best....
