T-Series stop lamp switch
roofinwilly
Anyone repair a hydraulic stop lamp switch for a bugeye? They are the same unit used on an early B. I've got juice, good circuits, good lamps. Guess the switch is bad but don't see how it could. Would like to get lights working today. I'll post on MGB forum also.
Thanks in advande for any help.
Bill
About the only thing you can do is to try to spray the inside with brake cleaner, through the pressure feed hole. Sometimes things get gummed up, and this will fix it. Other than that, they're less than 10 bucks and available.
Jeff
