Still Learning, please answer a few questions?
Gel
Member
1. How do I take the door trim panel off? I undid all the screws, handles etc. Is it stuck on as it won't budge and I don't want to force it? I would have thought it would have been held on with clips/buttons.
2. The passenger door gradually goes to about 1/2 inch out of line running from front to back but just on the bottom. It seems to be warped! Can this be fixed or is it a case of needing a new door?
3. Is the quarter light frame assembly difficult to remove. The frame is cracked on the corner and I want to replace it.
Thanks for all your help!
1. There's a good thread on removing door panels here...
https://www.britishcarforum.com/ubbthread...p;page=2#223800
You do have the upper part off right?
2. is the gap different by 1/2 inch, or is the door inset (or twisted in or out) at the bottom? Got a picture of that?
3. Once the door panel is off, you'll see most of the bolts that have to come off to get the frame out. There's also 2 bolts inside the front edge of the door near the top (only visible with the door open), and probably has plastic covers over the access holes.
