terriphill
I am truly beginning to believe this car hates me!!! Finally, runs beautifully, starts, purrs, new monza exhaust, new interior etc and I still cannot get the lights to works.
I have headlights, front running lights, signals.
Rear- NO back up lights, no running lights, right turn signal works fine, no brakes, no left turn signal.
When I use a tester to check for current to the left turn signal it is a constant not on and off. No current at all to the brakes or running lights. The trunk light works!
Is this a short?
Bad ground?
Bad flashers?
Why don't the brake lights work? Where am I losing connection!
I really don't expect a reply to this I just needed to vent a little!
I will get back out there today and walk through it all again.
Thanks,
Terri
Is this a short?
Bad ground?
Bad flashers?
Thanks,
Terri
