I have just finished a total restoration on a 1954 TR-2 Long Door. I replaced most of the suspension parts; ball joints,tie rod end assys inner and outer.
With the car jacked up, the wheel moves back and forth freely, easy to turn the steering wheel. The alighnment seems fine. When on the ground, it is very hard to turn the wheel either direction.I have added grease through the plug in the column, under the rubber plug. Probably put to much in as alot leaked out. I did not take the steering box apart. I have not tried to make a adjustment from the top of the box. Do you think that will loosen the stiffness?
Dick Vinal
Dick Vinal
