Kleykamp
clutch plate sticking. freed by bumping starter in gear. drove car around neighborhood and experienced judder. I slipped clutch by starting out in fourth gear several times and the judder stopped and worked great. I put the car away and came back several hours later...clutch stuck again. Question is, how long would one mess around trying to "clean" clutch plate. 2) would you replace just the clutch plate or do the 3 in 1 kit. Money is an object as I just spent mega bucks to do front suspension. My labor is dirt cheap, but I'm not wild about pulling the trans more times than necessary. Right now I'm thinking pull and check parts, clean up pressure plate and fly wheel and replace only the driven plate if no other significant wear found. Thought?
Hi Guest!
