boxfullofyertoys
Hey everyone!
Decided to finally do the toe-in on the Midget after all the suspension work, and sure enough the steering wheel was way off center when I finally got everything dialed in properly (did the 1/2 lock-to-lock trick to find true center on the rack).
When I went to remove the steering wheel to realign it... well...it doesn't want to come off. I've since removed the 6(?) bolts and the outer part of the wheel so it's just a hub, and attempted to use a jaw puller on it but I'm not having any luck getting it to budge.
Anyone out there have any tips/tricks for pulling it off the splines? I was thinking a slide hammer but I'm really nervous about damaging it as it's a collapsible column...
As always, thanks for the help!
