Nunyas
Hi all,
I'm thinking about replacing my steering rack gaiters/seals/boots or what have ya this weekend if I can get the tie-robs to separate from the steering arms (I've tried several times in the past with no luck... I have a pitman arm puller/tie-rod end sepparator tool to help this time). I was wondering what type of fluid to refill it with. Also, where is the place to refill it at? Is it by removing the cover on the pinion box and refilling there?
thanks
thanks
