I removed the steering box on my BJ7 because of play in the center tight position. Based on advice from the several experts on this website I was hoping the problem was end play in the steering shaft. But, I found wear on the spiral gear instead, probably from a history of shimming. A small depression is worn into the worm gear. It can't be adjusted out without being too tight as the steering wheel is turned past. Question is can the worm gear gear be machined and does anyone know a recommended shop. Obviously, it's not a part to compromise.
