Hello all,
I am doing some front end work on my 67 BJ8. After having everything pulled apart, I noticed a zerk fitting on the oil fill plug of the steering box. Is this normal? I have not seen anything that would say it was.
I pulled the plug to check if the box was filled with greased and it wasn't. But, it also did not have much oil in it. The gears are wet, but the level is below where I can see peering in through the fill plug. It appears that someone has squirted some grease through the zerk at some point. It looks like the box was taken apart at some point since the cover plates have orange high temp sealant. It has also been painted since the zerk is also black. There is no excessive play anywhere that can’t be taken out with a little adjustment and the arm shaft does not have any side-to-side play. The box is pretty dry on the outside, so there hasn’t been any oil leaking lately. Since the oil is low, I was planning on changing the shaft seal at the bottom before refilling.
Do you think I should split and inspect the box and/or rebuild the box?
Thanks,
Mark
Thanks,
Mark
