CJD
For the 2 covers on the steering box, a gasket goes on the casting, then a steel or brass shim, and finally the cover. so the gasket seals the shim to the casting. But nothing seals the shim to the cover...I know this because the shims came off clean and easily on disassembly. It's no wonder they leak!
Are you guys using sealant on the shims when you reassemble the covers?
