Hello people.. OK, why is the lower mounting hole in the mounting bracket (trunnion bracket) enlarged? ie upper bolt hole is 5/16, lower is 9/16. Reading between the lines of other posts, it may be adjustment slop for the steering column alignment. But I may have lost a special bolt or sleeve. It's been quite a while since I disassembled the front end.
While on the steering box subject, how would I know if the box needs rebuilding. Is there something I can pull or shake to tell me if there is too much backlash in the gear..or whatever goes bad? It's a split column and there doesn't seem to be any play or lag between turning the upper half of the column and movement of the drop arm. Or..should it be restored routinely every 60 years. I'd rather not but I would. Thanks
