steering box oil seal
tomnanney
I have to change the oil seal on my steering box.(1967 BJ8)
Can I just remove the steering arm and take the seal out, or do I have to take the box apart? Also, it seems like I read somewhere that someone had used two seals instead of just one? What this was for I'm not sure. Any help is appreciated!
thanks tom
Can I just remove the steering arm and take the seal out,--
Yes it is that simple TOM.
or do I have to take the box apart?----NO!!!! :nonod:
Yes the narrower seals are available from MOSS I think. However, using narrower two seals they only occupy the same space as the original single one but they :
1] Increase the pressure on the shaft and place it at two new places which avoids the old worn spot.
2] They seal on a slightly different spot on the shaft enhancing the potential of a better fit. ----Fwiw--Keoke
tom
For all the good reasons Keoke says...
