Steve Huneck
Member
Hi,
I'm trying to replace an oil seal in my BJ7. I'm amazed at how hard it is to replace a $3 part, but I digress. This is the seal that the rocker arm goes through at the bottom of the steering box. The old one was soft rubber and I was able to pop it out. However the new one seems to be nylon or a hard plastic. And I cannot fit it behind a metal lip on the bottom of the steering box. The lip seems to be part of a pressed in sleeve that holds the seal in place. However I don't see any reference to this in either my service manual or parts manual. I can probably bend it up with a screw driver, put in the seal and bend it back, but that just doesn't sound like the best approach. I have attached a picture, looking up from the bottom of the steering box. Any thoughts?
Thanks,
Steve
Thanks,
Steve
