Bob_Spidell
Looks like I've goofed somehow. I was finishing installing my new Lempert steering wheel on my BN2 and had a problem getting the stator tube back down through the steering box (I think it was catching at the 'stud' on the end plate that the olive gets bolted-up to). Anyway, after no success finagling the tube through the hole I made the idiotic move of pulling the end plate off the steering box. I've done this before to apply some sealant to the plate and shims to stop leaking, but this time the lower bearings and their race fell out. No amount of sworking can get the bearings and race back into the box far enough that the plate can be pulled fully down, even with a 1/32" or so of shim packing; if I pull the bolts down the steering locks up. I've studied the shop (Moss) diagram, and there are matching bearings and race at the upper and lower ends of the box; thinking the upper might have slipped out of place I pulled the top cover off the box, but I don't see anything loose or out of place. No matter how carefully I try to pull the bolts down on the end plate I'm having no luck getting the lower bearing and race into the box. Anybody have any ideas? Been stuck in this predicament before? I've tried moving the wheel from lock-to-lock and centered and everywhere in between, but it seems as if the steering shaft has moved down a 1/16" or more, making it impossible to get the bearing and cup back in sufficiently far. Oh, and I did all the tightening and adjusting of the steering wheel before I pulled the cover off the box so I don't think the installation of the wheel had anything to do with this.
Who can bail me out of this predicament? If I don't get this resolved, my beautiful new steering wheel will be a static display only
