I have reached the point where I am about to tighten mount casting bolts and then the drop arm. The drop arm is lined up with a mark on the rocker shaft and the one on the mount casting. Nothing has been tightened down yet. If you are standing above the box looking down it seems that the drop arm is positioned slightly over the main steering tube wheras in photos I have seen the drop arm would appear to be on somewhat of an angle from the shaft...a few degrees over? Dosn't look right.Anyone have an idea of what is going on here? I did use components from two different steering boxes so the markings may be wrong? If so how do I get back to proper alignment?
Also ...if you were turning the shaft from lock to lock would you get the exact amount of turns from one side to the other? What if you turned the shaft all the way right and it was 2 turns but when you turned all the way left you got 2 turns plus 3/4"?
Karl
Karl
