Steer Rack
DNK
K, the bro woke up his 72 B after a winters slumber.
Says the steering is pretty stiff.
Asked him if he has ever added fluid to it and he says he can't figure out where.
So what's the scoop on B steering racks
IIRC, you have to pour it into one of the boots with it off just a bit...
'72 should have a threaded plug (or possibly still has what appears to be an oversized grease fitting) over the junction where the steering shaft and rack join. Supposed to put gear oil in there. And ounces, not pints.
Be a good bro and get him a Bentley manual! :wink:
apparently i don't :blush:
Put some grease in the king pins, it gets real thick in cold weather. Bring it down to NC and you won't have a problem, 95 today. My son just left your neck of the woods for Scotland and you finally get some days in the 80's.
Wayne
He has one and I guess his must be written in some cock ney'd accent as he can't figure it out and he's fairly level headed :laugh:
for an older bro!
Okay, I'll play straight man...
Section J, at the first paragraph, after the illustration is a description (page 222) for using an OIL gun to lube the rack. If there is no fitting he will need to remove the two 7/16" headed bolts keeping the cover, shims, spring and tensioner puck in place and pour a couple ounces into the rack.
The REAL issue may be the bushings in the column. One at the lower end can get dry and a bit of oil can make a big difference. Older ones are felt and NEED oil, his (IIRC) may be nylon. Either way, if the lower end of the shaft gets corroded it will stiffen the steering.
HTH.
And silly me. Being born in Texas, I thought you were talking about this steer rack:
I'd still verify the tire pressure. They can loose a few pounds sitting over the winter at times and that will cause very heavy steering.
:iagree:
Shawn said:
I'd still verify the tire pressure. <span style="font-style: italic"><span style="font-weight: bold">They can loose a few pounds sitting over the winter at times</span></span> and that will cause very heavy steering.
Over the winter I get a few loose pounds, too. And it does seem heavy steering is a consequence! :wink: :jester:
EDIT: Couldn't pass it up, Shawn... *sorry*</span>
See, I tend to gain a few pounds when I sit over winter. Maybe I should switch to CABs. :wink:
Yea, I see the mistake, don't feel like correcting it though.
Took a gander at it Doc, couldn't see a spot for the nipple.
Did find a torn boot on the drivers side
The rack is then a "new" version, they seem to have decided too many Yanks thought it should get grease. Just remove the plate and pour some gear oil in there. AFTER you swap out the torn boot.
Thought the same thing and asked him that,
He bought the car from a good friend of his and he hasn't replace the rack nor is there a receipt for it he claims
Meant "new" as in 'after 1968'. Doubt his was replaced from original.
This is what it should look like. This is on a TF, but their basically the same. PJ
