I have notice a knock or clunk sometimes when starting from being stopped in first gear. Not always, but most of the time.
Anyway, checked the ujoints by raising car and having in neutral and twisiting things and can't find any slop. However, the right rear hub does have some play, not alot but it will move, the left does not.
Also the differential input shaft has slop or backlash. I would say a 1/16 of an inch or so, quite noticeable. It this to much? Is the hub bearing or the diff the culprite? or both? All the diff mounts have been replaced by PO with poly and look secure.
Where is a good place to get a rebuild diff it that's what's needed?
Thanks
Thanks
Hi Guest!
