Frank C.
Every now and then when I try to start my BJ8 the starter barely can turn over the engine. If I try a few times it usually turns over fine. The battery is new and fully charged and all my connections seem tight so I'm thinking (hoping) it is dirty contacts on the solenoid and not the starter. My question is, can I pull the solenoid off and clean/rework it or is a sealed unit that I should just replace?
As usual --- thanks in advance.
Hi Guest!
