Starter Solenoid Buzzes when trying to start
Hegg
When I attempt to start my car, I hear a buzzing sound coming from the solenoid. Where should I start troubleshooting? The starter tested positive at AutoZone this morning.
Thanks!
Hegg
The most likely problem is a bad battery cable connection somewhere, or possibly a low or defective battery. For some reason, the voltage at the solenoid is going very low when a load is put on the system. A quick check is to see if the headlights go very low or out when you try to start. If they are not bright before trying to start, the battery is low.
I've got it jumped to my Falcon -- which I know is good cuz I drive it every day. I'll check the cables a bit more thoroughly.
