Sledgehammer
Member
I'm trying to remove and replace a starter in a 64 MGB. First how do you get the old one out??? I've removed the bolts and wire attached but can't get it out of the space due to the "long" starter shaft and not enough room. Can it be pulled without removing the distributor, etc.?
Second, I ordered a High Torque starter from Moss. The bodies are different as I expected but the new one doesn't have the same "long" shaft as the old one. The old one has what looks like a bunch of "large washers" on the end of the shaft next to the gear that goes into the housing and they actually come out the back side of the housing thru an opening. Do I have the wrong Starter or does this new starter not need those "washers"?
Thanks in advance!
Carl
Thanks in advance!
Carl
