fwtexasbj8
This is a continuation of my Fuel Pump Priming post but with a new diagnosis! I have been digging into my problem and discovered I only have slightly over 6 volts on the positive side of the coil. All other coil checks seem to indicate the coil is good. I have traced the wiring into the coil back and found the white/yellow wire at the starter relay has only the same 6 volts. The power into the relay is battery voltage of 12.3 volts. Does the starter relay essentially power the coil and could a bad connection inside the relay yield a lower voltage and therefore rough running and no engine power?
As usual, I appreciate all the help
