Nelson
Yesterday I tried to begin the process of starting my engine after a rebuild. I pulled the plugs and connected the new battery to only the starter pull switch and the engine block. The engine turned over when the switch was pulled. I was wanting to get a buildup of oil pressure prior to having the engine run. It turned over for maybe 20 seconds and just stopped. Continuity of the switch was OK and so were the battery connections. Then I connected the battery directly to the starter and it still did not turn. Today I pulled the starter and with it sitting on the floor it spun very quickly and the bendix gear seemed to be working properly. With a wrench on the crankcase nut the engine can be turned over by hand. Is there such a thing as a weak starter. Tomorrow I'll take it somewhere to get it tested if that is possible.
