100DashSix
So I took my MG to watch the sun set over the water, and ended up watching the stars come out one by one, as the car wouldn't start after I parked it.
Ignition warning light, click of the relay, and nothing else. The connections to the battery look good, as does the ground strap on the engine. When I investigated under the car, I determined that three wires connected to the "Solenoid battery terminal" were there, but one wire (white with brown tracer) was hanging loose, the spade connector disconnected. Fortunately my father happened to be coming back from Miami, of all places, and was able to stop by and push the car with his so that I could pop the clutch and start it.
I attempted, as I was stranded, to connect a hot lead from the fusebox to what Haynes says is the starter's "STA terminal." Though I don't know what this stands for, tapping it with power makes the starter spin, though not engage with the flywheel. Likewise, the white and brown-lined wire, when connected to the STA terminal, will spark and release precious smoke when the key is turned, causing spinning.
Is this where the wire goes? I see no place to connect the spade connector at all. What needs to be connected to the starter? How can I diagnose this problem?
Help for my garage-entombed MGB is much appreciated.
