I've been driving my '64 TR4 all summer and have never had a (major) problem with starting. Once in a while the Bendix spring pops out and I have to re-crank.
Anyway, after sitting for about 2 weeks in normal weather (Cincinnati - rain, heat, humidity) I returned from a trip and went to fire her up. She started right away, normal. I turned her off and tested a new windshield wiper motor I just purchased. Motor works so off to the store to buy some grease for the cable.
"Click"
Several clicks later I saw a bit of smoke coming from the starter motor. It looks like it's locked up.
There were no indications of a problem before this incident. I'll be pulling the starter motor this weekend but I wanted to know if there is a known issue with starter motors and this condition. In otherwords, what should I expect when I pull off the motor?
(I did start the engine and drive it to the store (parked on an incline) and there was no sound like the pinion gear jammed into the flywheel gear.)
"Click"
