Webb Sledge
Sometimes when I go to start my car the starter will just grind against the flywheel, instead of engaging completely. This doesn't always happen, but will sometimes, and rarely it will do it a second time after I've flipped the key to off, waited for it to stop spinning, and then try to crank again. I think it needs a new relay or starter. What do you think?
Also, sometimes when I go to put it in reverse, the gears will grind, even with the clutch as far as it will go (ie, to the firewall). This is embarrasing, but moreso it's bad for the gears. Could it be the throwout bearing that's sqealing again? The bearing needs to be replaced regardless of the gear problem. Suggestions?
