Webb Sledge
I started overhauling my TR6 engine today. Had to take some of the interior out (center console, tranny tunnel, sterio, seats, carpet) to unhook the transmission from the engine, and then disconnected all that was connected to the engine from the car. Grabbed a bigass engine hoist, and lifted her out (after the ritual beating, cursing, and deftly smashed fingers). Fuel, oil, and water pumps were removed, along with the coil, distributor, clutch, flywheel, and the oil was drained. Then it was set on a table and the hoist removed. Turning that thing on its side without dropping it was hard as heck. TRs have iron blocks, remember, not fancy modern aluminum so it weighed about as much as my house. Then we got the various valve train bits out and head off. Bottom end next; bearing caps and main bearings out, and then big ends of the con rods off. Crank removed (also weights as much as my house), and valve cover, tensioner, and chain taken off. We then took the pistons out. The cam came out next, after beating on the lifters for 30 minutes trying to figure out which one was holding the cam in, and then the lifters got popped out. By that time the engine was down to bare block, and ready to be taken to a machine shop for measuring of clearances and the possibly, probable boring.
My engine is completely original, except for a timing chain and main bearings, so it's going to need a bit of work, though not excessive. The lifters ate my cam, and both are pitted and the rule is you shouldn't ever replace just the lifters or just the cam, as they'll just destory each other again, so I've gotta have $60 worth of lifters, and a $330 cam... dangit. When it's all done though my car is gonna kick some serious ass. I'm replacing the dual Zenith-Strombergs with twin Webers, a free flowing intake manifold, and a Pacesetter Monza exhaust. I can't wait. Before we started on this, it had basically no compression (bad rings. We couldn't even get the head to pop off with compession because it leaked around the rings so badly), less than 40psi oil pressure at full throttle, though the gauge read about 65 because it was rigged with a bolt. Even with all that wrong, it pulled moderately well at low revs, so I can't wait to see what a proper 6 engine with some hop-ups can do.
