This has been a rough few weeks and I'm still no closer to getting my engine running. Three weeks ago, I tried to start the engine for the first time since a complete hi-performance re-build over the winter and found the original starter wasn't up to snuff. Bought a gear reduction type, installed it the following week. After swapping that out, I got the engine to run (and it started easily) only to find that it was overheating. So I had the car towed to my house so I could flush the cooling system (dirt driveway and a sill cock nearby). Did that this past Saturday and nothing was clogged (except for the heater core, which took about a half hour of flushing and back-flushing until the water was running clear).
Everything is back together and all I did was flush the system, I swear! and now the motor won't start! At first, I had no spark; found that the earth lead wire inside the distributor was fraying. Re-soldered a new wire in place last night and got my spark back. It still won't start. Checked the fuel pump and it is pushing gas up to the carbs (dual downdraft Webers).
I have checked the following: correct firing order and spark plug wires are in their proper place; fuel pump appears to be working; ignition switch continuity test shows it's working properly; starter spins when the key is switched on; coil tests shows that it's ok (tried a spare to make sure and it didn't make a difference; I have a new one coming just in case.) Electronic ignition seems to be working, as it is sending a spark to the plugs; I bought a new rotor button and have swapped out a couple of distributor caps; still nothing. /ubbthreads/images/graemlins/crazyeyes.gif
The funny thing is it was running a couple of weeks ago, although overheating, and now it won't even catch. Maybe I'm missing something obvious here. I'm almost to the point of having this thing towed to a mechanic, figuring he would have the experience and the proper diagnostic tools to solve this mystery. I'm getting anxious to take this thing out for a drive and my wife is looking at me with a look that says "That was $6000. well spent".
